Flat Wall & Small Shutters
A project log for Air Quality Pavilion: Rethinking Shared Spaces
The Air Quality Pavilion uses an internal sensor to collect data, monitor & then trigger various reactions to the CO2 levels
avyeAvye 10/14/2022 at 13:240 Comments
The flat wall was a lot simpler to create as it wasn’t built up in layers and therefore needed less material. The louvres were smaller & lighter so that a much smaller stepper motor could be used to open and close them. Plus it gave me an opportunity to explore a different way of attaching the louvres to the wall.
