About Allwinner H616
H616 is a new-generation high picture quality 64-bit 4K@60fps decoding SoC provided by Allwinner for the OTT and IPTV markets. It integrates the quad core 64-bit CortexTM-A53 processor, and the new G31 GPU engine of ARM that supports OpenGL ES 3.2/Vulkan 1.1. Besides, H616 supports full-format 4K@60fps 10-bit ultra-HD video decoding, Allwinner self-developed SmartColor3.3TM picture enhancement engine, Dolby, and DTS audio processing. H616 adopts the new generation of power consumption technology, and reduces power consumption of 20% than the last generation.
Chip Blocks
brief
Feature
  • Based on Allwinner H616 chip, 4*Cortex A53
  • HDMI supports 4K@60, supports up to 6K video decoding
  • Up to 2GB RAM and 128GB eMMC storage
  • Onboard eMMC and TF card slot
  • Onboard XR829 WIFI+Bluetooth chip
  • 4 USB Type C, 3 HOST and one OTG, support USB camera and capture card input
  • Onboard fan slot, radiator fixing hole
  • Lead out RJ45 100M interface
  • Onboard 40 Pin GPIO, can expand SPI LCD display, Gigabit Ethernet, microphone array, CAN transceiver, temperature and humidity sensor, acceleration sensor and so on.
  • AXP313A Power Solution
  • Raspberry Pi A Size
Notice
H616 does not have a built-in PHY LED interface. If you need to lead out the LED, you need to use an independent GPIO and configure the software.
OS
  • Ubuntu 20.04
  • Armbian
  • Tina Linux
  • Android TV 10
  • Android TV 12
  • Android Auto
