Fabricating
A project log for Luggable Cyberdeck
Watercooled MATx build with built in goodies for plug-n-play computing and art.
tracespazerTraceSpazer 10/03/2022 at 03:290 Comments
I really wanted a cool tube full of neon-colored liquid on this project somewhere. So, I scoured the internet and found a good deal on 2.25" Diameter, clear polycarbonate tubing. (Wound up with 8' of the stuff.) And then found 2.25" diameter Rod to go with it.
The tube became the body and the rod was cut and then machined on the lathe to fit within it with G1/4 threads.
