Mini-Deck IR PCB Mount 3.0.scadMount for 20mm x 80mm prototyping PCBscad - 2.10 kB - 08/07/2023 at 18:20 |
Mini-Deck I2C Hub Hinge Top 3.0.scadHinge for Adafruit Qwiic / Stemma QT 5 Port Hubscad - 1.04 kB - 08/03/2023 at 20:39 |
Mini-Deck Keyboard Platform 3.0.scadKeyboard half of reverse clamshellscad - 2.07 kB - 08/03/2023 at 20:39 |
Mini-Deck OLED Generic 128x32 Hinge Top 3.0.scadHinge for generic 128x32 OLEDscad - 1019.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck Magnetic Battery Connector Cover 3.0.scadCap for magnetic battery connectorsscad - 447.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck Camera Ribbon Shield 3.0.scadCamera ribbon shieldscad - 626.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck BME688 Mount 3.0.scadBME688 mountscad - 698.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck Camera Fronting 3.0.scadSpyCam front framescad - 426.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck MAX17048 Mount and Washers 3.0.scadMount for MAX17048 battery gauge and washers for m2 screwsscad - 1.55 kB - 08/03/2023 at 20:39 |
Mini-Deck OLED 128x128 Hinge Top 3.0.scadHinge for Adafruit Grayscale 1.5" 128x128 OLED Graphic Display (not used)scad - 1.09 kB - 08/03/2023 at 20:39 |
Mini-Deck OLED Bracket 3.0.scadBracket for hinged attachments around the main displayscad - 3.11 kB - 08/03/2023 at 20:39 |
Mini-Deck Keyboard Rails 3.0.scadKeyboard railsscad - 3.74 kB - 08/03/2023 at 20:39 |
Mini-Deck Camera Backing 3.0.scadCamera backplatescad - 363.00 bytes - 08/03/2023 at 20:39 |
Mini-Deck OLED 128x64 Hinge Top 3.0.scadHinge for Monochrome 1.3" 128x64 OLED graphic displayscad - 1.10 kB - 08/03/2023 at 20:39 |
Mini-Deck Battery Holder 3.0.scadMain Raspberry Pi half of clamshellscad - 2.90 kB - 08/03/2023 at 20:39 |
Mini-Deck OLED 128x32 Hinge Top 3.0.scadHinge for Monochrome 0.91" 128x32 I2C OLED Displayscad - 1.09 kB - 08/03/2023 at 20:39 |
