You can find the cleaned up designfiles including testbench and assembler on Github.
I ported two program examples from my other processor designs: Fibonacci number calculation and a prime number search algorithm.
Fibonacci examples seem to be quite commonplace for minimal processor implementations. However, Fibonacci can be implemented on a machine without any decision making (branching). So, proving that an architecture is able to execute Fibonacci is possibly not a proof of Turing completeness. This is why I prefer the prime number search.
The Fibonacci implementation is straightforward and shown below:
.=0
init:
LDI 0
STA R0 ; a = 0
LDI 1
STA R1 ; b = 1
loop:
LDA R1
STA R2 ; temp = b
ADD R0
STA R1 ; b' = a + b
LDA R2
STA R0 ; a = b
OUT ; display b
BCC loop
idle:
BCC idle
The testbench will show the output of the executed programs directly in the shell. In addition, a VCD file with waveforms is generated, which can be viewed with GTKWAVE or the WaveTrace plugin in VSCode.
The number in brackets shows the number of executed program cycles, the output shows the content of the accumulator when the "OUT" instruction in the machine code is executed.
; divisor=2;
; while (divisor<number)
; test=-number;
; while (test<0) test+=divisor;
; if (test==0) return 0;
; divisor+=1;
; return 1;
number = R0
divisor = R1
allone = R7
.=0
start:
LDI -1
STA allone
LDI 2
STA number
OUT ; first prime is 2
outerloop:
LDI 2
STA divisor ;divisor = 2
LDI 1
ADD number
STA number
loop:
LDA number ; test=-number;
NEG
innerloop:
ADD divisor ; while (test<0) test+=divisor;
BCCL innerloop
ADD allone ; if (test==0) return 0;
BCCL outerloop ; No prime
LDI 1 ; divisor+=1;
ADD divisor
STA divisor
NEG ; while (divisor<number)
ADD number
BCCL loop
prime:
LDA number ; Display prime number
OUT
JMP outerloop
Tim
