New casing and more
A project log for ESP32 Dual-screen watch
A smartwatch designed to have many functions whilst utilizing a unique dual-OLED display for visual complexity!
David TruongDavid Truong 09/30/2022 at 01:550 Comments
After several iterations, I decided that I would need to 3-d print a new case, so that's what I did, along with a few sacrifices to ensure that the watch is smaller than before. For example, I decided to make the GPS module removable and removed the entire charger board inside so you can use it externally.
