CM4108256
CM4 module with 256GB eMMC
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The aim of the project was to modify the eMMC memory (by soldering) from the default 32GB (SAMSUNG KLMBG2JETD-B041) to 256GB (SanDisk SDINBDD4-256G), ie to create a unique, custom CM4108256 ("Little Big Monster") configuration, which is not available on the market. For this purpose, a brand new Raspberry Pi CM4 module was used in the maximum configuration: 8GB RAM + 32GB eMMC + WiFi (CM4108032).
The following model (v5.1 standard) was used as eMMC memory: SanDisk iNAND7350, part number SDINBDD4-256G, in the BGA153 package.
More about the project:
https://github.com/mfolejewski/CM4_256GB_CM4108256/
