Polymax PC (PC-Max) 3kg roll on top of a food dehydrator (165F max temp). All the food trays were cut out of the rings to make a dryer just big enough for the roll. The polycarbonate doesn't really need drying it seems, and it helps to use it inside an enclosure. Nylons and ASA definitely need to be dried and bagged before use.
