Standard Tesselated Geometry - 8.48 MB - 02/27/2024 at 21:20 |
fusion - 1.55 MB - 02/27/2024 at 21:20 |
PsuedoPancakev2b.objPsuedoPancakev2b, fixed lens to display distanceobj - 120.27 kB - 10/27/2023 at 14:41 |
Boson Print.objMain v2 print file with IPD system, lens holder, etc, small fix needed for display to eye distance (literal penny thickness addition needed)obj - 453.83 kB - 10/26/2023 at 22:32 |
Boson Skeleton.zipA file showing the parts generally togetherx-zip-compressed - 129.12 kB - 10/26/2023 at 22:32 |
PsuedoPancakes v2.svgThe lens you want to cut, remember use 2 60mm and 2 70mm! Also ensure you flip one 60mm and 70mm so all have the smooth end facing the user's eyesvg+xml - 2.74 kB - 10/26/2023 at 22:32 |
VGLensHolderv1.stlVersion one of the lens holder (check for errors!)Standard Tesselated Geometry - 68.25 kB - 04/19/2023 at 00:15 |
VGLens3DModelv1.stlVersion one of the lens, represented as a 3D model (check for errors!)Standard Tesselated Geometry - 14.93 kB - 04/19/2023 at 00:15 |
Vector Gear DXF File For Cutting.dxfVG Lens 1.0 DXF file for cutting!AutoCAD DXF - 6.77 kB - 04/19/2023 at 00:07 |
