keyboard_mount_mk2.stlArms that connect to the case to the keyboard tray.Standard Tesselated Geometry - 471.86 kB - 09/18/2022 at 16:02 |
keyboard_clip.3.stlClip that holds the keyboard when it is folded up and closedStandard Tesselated Geometry - 19.61 kB - 09/18/2022 at 16:02 |
keyboard_base_supports_mk2.stlPlate that holds the folding bluetooth keyboard.Standard Tesselated Geometry - 379.38 kB - 09/18/2022 at 16:02 |
mount-convert4.stlTripod mount/converter for the 10" monitor on the side of the case.Standard Tesselated Geometry - 162.78 kB - 09/18/2022 at 16:01 |
Monitor_backplate_mk3.stlHolds the 5.5 WaveShare display in the place where the CRT went.Standard Tesselated Geometry - 157.89 kB - 09/18/2022 at 16:01 |
