Making a literal digital clock
This is the start of a bigger project, splitting it up in different pieces.
Sit back and relax, its gonna take some time ;-)
Public Chat
Using an ESP32, and double shaft stepper motor x40 I will create an analog clock that despite its looks is digital. I will be 3D printing and designing the whole thing from the ground up. Although you might catch me slippin on the hardware side, as I'm more of a software guy.
Github: https://github.com/flamefir/SingleClock
What you will see in my project.
- Mistakes
- Mistakes
- Small Progress
- More Mistakes
and then we loop until we are done with the project.
The plan!
To make a smart clock with some cool formations of the pointers!
  • I will use ESP32 as my board. Why you might ask? They have wifi, bluetooth, many IO pins for its size and they are quite inexpensive when bought from china.
  • For the motors I first tried to design my own dual shaft stepper motor with two small stepper motors and many gears! Then after designing for a small month, I realized    that China obviously already have this. I will be testing the X40 china copy of Switec and the less expensive BKA30D-R5.
  • To keep track on time I will either use WiFi or RTC.
  • To keep track on the pointers location, I will try to brute force a software solution with saving the steps in the EEPROM, if this fails I could probably use a retro reflector sensor.
  • To get familiarized with driver motor, I will use the infamous x12.17 stepper driver which also allows microstepping. This allows me to cut the I/O pins needed in half. The driver can control two double shafted stepper 4 wire motors. A double shafted motor, is basically two single shafted motors that use 4 wires, so in total 16 motor wires can be controlled with the x12.17. Each motor needs a direction and how many steps it should take so that's 8 pins, hence the I/O pins gets cut in half.
I might make some sketchy PCB design and solder a prototype.
Then we take our hammer and mallet and put it together, how hard can it be?
  • 1 × ESP32 Microcontroller
  • 1 × X40 double shaft motor Get the version without end stops, to get 360 degrees freedom
  • 1 × DS1307 Module RTC - real time clock But any RTC will probably work
  • 1 × M-S Quad Driver X12.017 THIS IS NOT STRICTLY NECESSARY, but I will be using it. You could drive the motor directly from microcontroller
  • 1 × 3D printer or access to a makerlab
View all 6 components
  • Review - PCB's sponsored by PCBWAY
    flamefire12/26/2022 at 10:28 0 comments
    PCBWay reached out to me through hackaday, and they offered to sponsor my PCB's for my project! In return they wanted a few words on the quality and service they offer.  PCBWay even sponsored the delivery costs which was really awesome. Making projects as an student can be quite expensive, so i humbly accept their offer, and the following is my experience with PCBWays service and quality.
    My design of the PCB made with the EasyEDA software. This is my first time designing a PCB, so dont go hatin', I have made a mistake in the routing from analog sensors to digital ports on the MCU and i have to modify my design files. Otherwise anyone would be able to download the design files and make their own PCB order if they choose to make this project.
    Topside:
    Buttomside:
    Once you have the GERBER files its very easy to order PCB's through their website. I choose to make the PCB's black, and i must say they look very cool!
    Once you have ordered PCB's they will check your design, before production. I made an error in quantity, and i wrote to customer service. In no time customer service fixed the issue with no problems. Its also possible to change the GERBER files before production, just write to customer service and they will fix your problems.
    If i remember correctly i choose a delivery option to 15 days so that the PCB's would arrive before christmas. They arrived after 12 days and was nicely protected.
    Im no expert, but the quality of the PCB's feels very professional. I have checked the routing connections and  they all have a solid connections. It was also very nice to solder the pads.
    In conclusion i would recommend PCBWay, its easy to order PCB's and the quality is very high.
  • 23/12 - 2022 - The assembly and project (done)
    flamefire12/23/2022 at 15:56 0 comments
    The Result
    So lets start with the finished result. What went good and what went not so good.
    It can be seen in the video that the pointers is kind of slacking. They actually weigh to much! F me. That means that the whole system with magnets and hall effect sensor are not the solution to the homing system is probably not what i want.
    The video is a test of the PCBs do please see the review of the PCB's.
    This is the final look of the digital analog clock, to fix the weight of the pointers, i made them very thin, and removed the magnet ofcourse. Maybe some fine tuning could be done about the weight of the magnet and pointers to make it work, yet to be tested.
    THE BUILD
    Lets talk about what i did to build it.
    3D printer
    I 3D printed the whole casing on my ender5 3D printer. A lot of fine tuning was done, to make it fit together, and remember all 3D printers are different. For an example the holes for the M5 and M2 screws had to be very accurate for it to fit, the print could otherwise crack. Speaking from experience!
    To make it look more like an product, than homebrew i tried different sanding and smoothing techniques.
    1. I tried an mixture of acetone and putty, as i had seen in a guide. I feel like the result could be the best with this solution. However a lot of time is required. First you sand the 3D print down with very rough sandpaper. You then mix the acetone(very little) and putty then paint it on the 3D print and sand it down again, with more fine sandpaper. Keep sanding it down until smoothness is achieved. Then lastly paint it your favorite color and keep painting it until the putty cant be seen anymore. This was hard for me because it was painted white.
    2. A more simple solution is to apply filler spray and sand it down, keep repeating and lastly paint it.
    I found that this simple solution gave a better result.
    The PCB build
    If you have zero experience with soldering, i would watch a video first. I am definely not good at this, and this is my first time soldering such small components. Fortunately my school has great gear for soldering.
    There is a few errors in the PCB unfortunaly. The hall effect sensors are setup to non analog pins on the ESP32. And since the hall effect sensors are analog, this was not working as intended.  This is unfortunate but as said before, the whole homing system is not working because the pointers would weigh to much.
    Instead you set the pointers at 6 O'clock as precise as one can be, and turn on the system.  As also can be seen in the video.
  • 07/12/2022 - PCB's are here
    flamefire12/07/2022 at 15:32 0 comments
    The PCB's have arrived very quick, delivery was only 7 days. So far I'm very pleased with it, a more thorough review will be coming shortly. I'm also 3D printing a test case.
  • 11/30/2022 - 3D printer design
    flamefire11/30/2022 at 03:03 0 comments
    Ooooh finally! My favorite part is designing the 3D model. I have used Solidworks. The Clock will be able to be setup on the wall, however I have also made a version meant for the desk.
    These designs are almost done. Although I'm concerned with the hour and minute pointers being to close to the backside. The motor leaves very little space to be playing with. With the PCB at 1.6mm and the backside at 1.4mm thickness, and the space between PCB and backside, there will probably be 0.5mm. That leaves 0.5mm for the innermost pointer to the backside. Conclusion ... I will fix this problem somehow. I also need 3 buttons on the back
  • 11/24/2022 - PCB done
    flamefire11/24/2022 at 03:40 0 comments
    The PCB is done and I've also changed a few errors in the hardware schematic. There is also room for connecting another motor clock, because why not have the possibility. I have also added two hall effect sensor, just in case I want to make some sort of homing functionality. I have also added pin connections meant for some push buttons.
    Exciting stuff! Will hopefully get these babies from PCBWay soon. In the mean time I will 3D design some case for the clock.
  • 10-11-2022 - Found a bug
    flamefire11/10/2022 at 19:07 0 comments
    So since the start I had a bug where no matter what I did, the inner shaft would move randomly, continuously. Sometimes and sometimes not. I always thought that it was my shitty breadboards that was the cause for interference. However I figured I might try to set the RESET pin to 5V input instead of the 3.3V that the ESP provides.
    EVEN though the datasheet says otherwise. And of course that works..
    Will need to update Schematic to insert level shifter.
  • 11-10-2022 - God I hate Hardware design
    flamefire11/10/2022 at 00:46 0 comments
    So after spending literally a week figuring out how to make the best BMS system for my clock, while banging my head to the wall, I finally ... gave up. I know squat about battery systems. So a wired clock it is, for now. The schematic is done, and will begin on PCB.
  • 10-31-2022 Breadboard hardware design
    flamefire10/31/2022 at 02:44 0 comments
    I made a breadboard hardware design of the components.
    The original Fritzing file is on my GitHub to use for editing.
    Power consumption of 1A is estimated, will look deeper into that. I might even make it battery driven, for the clean look it could have.
    Next I will either make the PCB design or 3D design.
  • 28-10-2022 Ocean code clean up
    flamefire10/28/2022 at 07:49 0 comments
    I have succesfully formatted my 600 lines main.cpp into something a bit more beautiful. Made a few classes and turned my 600 lines into 100 lines. My ESP32 flash was really happy and went from 73% capacity to 50% ish capacity. I have also fixed the bug, where there was missing some steps over long time.
    I have pushed my project to github, both the ugly and less ugly code.
    The project: https://github.com/flamefir/SingleClock
    My last code revision: https://github.com/flamefir/SingleClock/tree/main/src/SingleClock%20-%20clean%20up%20code/SingleClock%20-%20clean%20up%20code
    As i am just a student, please tell if any code, makes you vommit.
  • 10-24-2022 final software test
    flamefire10/24/2022 at 19:22 0 comments
    Final software test proved good, ish
    Timelapse result:
    The video shows the analog time on both my phone and on the clock, they follow each other
    However the minute pointer is missing some steps, as can be seen in the video.
    Next I will fix this step error, then clean up the code!
View all 14 project logs
