10-11-2022 - Found a bug
A project log for Making a literal digital clock
This is the start of a bigger project, splitting it up in different pieces. Sit back and relax, its gonna take some time ;-)
flamefireflamefire 11/10/2022 at 19:070 Comments
So since the start I had a bug where no matter what I did, the inner shaft would move randomly, continuously. Sometimes and sometimes not. I always thought that it was my shitty breadboards that was the cause for interference. However I figured I might try to set the RESET pin to 5V input instead of the 3.3V that the ESP provides.
EVEN though the datasheet says otherwise. And of course that works..
Will need to update Schematic to insert level shifter.
