It's a bow tie, simply cut out of a bicycle inner tube, no sewing or other materials needed (except a printed A4 sheet of paper). It is one piece, but there is no opening mechanism nor is it adjustable in length.
A bow tie made out of upcycled bicycle inner tubes
scan_bowtie.pdfScan of a bow tieAdobe Portable Document Format - 332.76 kB - 09/21/2022 at 16:22 |
cutting-template.pdfCutting templateAdobe Portable Document Format - 9.79 kB - 09/20/2022 at 20:19 |
Print the cutting template on a A4 sheet of paper and cut out both bow tie ends.
Note that this version has not been tested yet. You can also create your own, e.g. by making use of the scanned bow tie. There are also plenty of other good cutting templates out there (direct link to PDF).
Find some tutorial how to tie a bow tie and tie the bow tie. The inner tube is elastic, so it can be pulled over your head without untying the bow tie.
