alignment_tool.stl
Tool to align the face plat upper side with the lower side, since these must be glued at an angle.
Standard Tesselated Geometry -
164.90 kB -
09/22/2022 at 22:06
Download
track_pad_bracket.stl
Mount plate for the track ball
2.03 MB -
09/22/2022 at 22:04
Download
power_plate.stl
Mount plate for the BMS and power switch
712.25 kB -
09/22/2022 at 22:04
Download
joycon_bracket_left.stl
Joy-con mount bracket.
609.74 kB -
09/22/2022 at 22:04
Download
top_switch_plate.stl
Mount plate for all the power switches and the user switches
421.52 kB -
09/22/2022 at 22:04
Download
lcd_bracket.stl
Mounting plate for the LCD and Jetson Nano board
1.22 MB -
09/22/2022 at 22:04
Download
joycon_bracket_right.stl
602.41 kB -
09/22/2022 at 22:04
Download
screw_cap.stl
Screw cap on bottom assembly (not necessary if you use short screws)
3.72 MB -
09/22/2022 at 21:59
Download
case_spacer_2.stl
Cylindrical spacer used to guide the screw for the top assembly mount to the case.
640.46 kB -
09/22/2022 at 21:59
Download
face_plate_right.stl
Face plate right section
601.52 kB -
09/22/2022 at 21:59
Download
case_mid_right.stl
Case mid right section
430.70 kB -
09/22/2022 at 21:59
Download
case_spacer_3.stl
638.87 kB -
09/22/2022 at 21:59
Download
face_plate_mid_left.stl
Face plate mid left section (speaker grill)
361.50 kB -
09/22/2022 at 21:59
Download
face_plate_left.stl
Face plate left section
332.40 kB -
09/22/2022 at 21:59
Download
face_plate_mid_right.stl
Face plate mid right section (speaker grill)
525.92 kB -
09/22/2022 at 21:59
Download
case_right.stl
Case right side (where the joy-con will be mounted)
514.05 kB -
09/22/2022 at 21:59
Download
case_left.stl
Case left side (where the joy-con will be mounted)
497.35 kB -
09/22/2022 at 21:59
Download
case_spacer_1.stl
575.31 kB -
09/22/2022 at 21:59
Download
case_mid_left.stl
Case mid left section
178.44 kB -
09/22/2022 at 21:59
Download
case_mid_bot_right.stl
Case bottom right section
7.34 kB -
09/22/2022 at 21:59
Download
case_mid_bot_left.stl
Case bottom left section
3.17 kB -
09/22/2022 at 21:59
Download
qb-cyberdeck-v70.f3d
Fusion-360-project-file. This file contains the original models of all the STL files uploaded here.
fusion -
4.77 MB -
09/22/2022 at 21:57
Download
