Release candidates of LC1 just arrived.
The bottom side is with a lot of exposed ground copper now, because it turns out it massively improves the performance of the touch keyboard.
Also, the battery hole is now a bit smaller, and the soldering rings for the capacitors - a bit wider.
All looks fine but need to assemble one for test anyway.
Wow, I didn't realize the mcu was inset too. You pulled out all the stops to make this as thin as possible. Pretty neat.
