New PCBs
A project log for ELLO LC1
World's thinnest fully standalone DIY computer - 2mm!!
knvdKn/vD 10/05/2022 at 14:371 Comment
Release candidates of LC1 just arrived.
The bottom side is with a lot of exposed ground copper now, because it turns out it massively improves the performance of the touch keyboard.
Also, the battery hole is now a bit smaller, and the soldering rings for the capacitors - a bit wider.
All looks fine but need to assemble one for test anyway.
James Hall wrote 10/06/2022 at 13:30 point
Wow, I didn't realize the mcu was inset too. You pulled out all the stops to make this as thin as possible. Pretty neat.
