Amphibian-Serial-Bus
Converting USB3.2 & Ethernet from anything. Analogy to animals that are flexible on land and sea (local interfaces, and external formats)
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
(Project will be intermittent and is not active until I finish the others).
The more I deal with routing cables around me, the more I wish they all adhered to a single standard bus and connection. This project is more like, several scattered small ones, where I have replaced some interface I had to deal with, with something that interfaces with a tree of USB nodes that eventually connect to my active devices.
