plain - 9.42 kB - 12/20/2022 at 07:52 |
ESP32_Power_Meter_SMD_V2.1.rarArduino IDE code V2.1Known bugs: - If you hook the wires in reverse, negative values will be displayed of the screen (which are not aligned properly) - If you monitor a battery and charge it 100mAh and then discharge 100mAh, the calculated energy transfer will be 0 RAR Archive - 15.07 kB - 10/02/2022 at 13:56 |
BOM_PCB_Power Logger SMD.csvPower Logger EasyEDA BOM V1Comma-Separated Values - 7.14 kB - 09/28/2022 at 18:58 |
PCB_Power Logger SMD.jsonPower Logger EasyEDA PCB File V1JavaScript Object Notation (JSON) - 1.04 MB - 09/28/2022 at 18:18 |
SCH_Power Logger SMD.jsonPower Logger EasyEDA Schematic File V1JavaScript Object Notation (JSON) - 191.07 kB - 09/28/2022 at 18:16 |
Schematic Power Logger SMD.pngPower Logger Schematic PNG V1Portable Network Graphics (PNG) - 298.96 kB - 09/28/2022 at 18:14 |
