Here's a peek at the packaging I settled on for the FC 2.0, sitting on top of my Glowforge laser cutter where most of the magic happens ;)
And here's one of the earliest pics I took of a couple black acrylic clocks I built (Does anyone want black acrylic cases instead of wood cases? Speak up!) Check out the filter effect in the lid that largely eliminates the LED glare at the bottom of the digits. This is the best way I've found to do the edge lighting and I love the results. Hope you like them too.
Maakbaas
Andrew Cooney
