the fine folks at pcbway did some amazing work! Their machining services have made it possible for a new monolithic aluminum drive module ! I’m so excited to get these installed, also! Suspension has been redesigned and will use oil filled shocks to dampen the erratic movement of the drive modules! Stay tuned!
