Output TTY
A project log for YGREC16 - YG's 16bits Relay Electric Computer
Fork of #AMBAP, here I discuss about the physical implementation of the bitslice architecture with russian РЭС15 (see what I did here?)
Yann Guidon / YGDESYann Guidon / YGDES 02/18/2017 at 13:008 Comments
I've been much less active lately for very good reasons, the most important being to renovate my whole workshop. I Had to let go of quite a lot of old gears but I found some "forgotten treasures" though (it's always a matter of perspective, of course).
One of them is a Sinclair SP200 dot matrix printer with the standard Centronics interface. 8-bits glory and shipped with the internal schematics and protocol ! What better peripheral output could I have ? I even have a stack of continuous paper for it...
I haven't tested it yet but it was bought around 1990 and I remember having to source a new ribbon in the mid-90s. Today the ink is certainly dry...
Who can help me rejuvenate the ink ribbon ?
Yann Guidon / YGDES wrote 03/24/2017 at 15:11 point
(note for later)
Per Neil's suggestion :  https://www.google.fr/search?q=printer+ribbon+reinker
Phil Wright wrote 02/20/2017 at 09:02 point
You have a lot of projects. How do you ever finish anything when you have so many going at once!
Yann Guidon / YGDES wrote 02/20/2017 at 09:14 point
Some are finished :-)
Ted Yapo wrote 02/21/2017 at 17:04 point
LOL.  I on the other hand, have never "finished" a project in my life.  I can pick something I threw together in a weekend ten years ago and rattle off five things I've always meant to improve, fix, or re-do.  If I waited to finish any one of them, I'd never get to work on anything new :-)
Yann Guidon / YGDES wrote 02/21/2017 at 17:51 point
Working for clients is a great way to break the neverending spiral of hacking :-)
But there must be a balance between finishing a project (which is really exhausting) and recuperation/recovery/creativity. Thankfully I have become better at this :-)
Ted Yapo wrote 02/18/2017 at 14:43 point
I remember spraying one with WD-40 at one point and manually winding it around to distribute the ink/solvent.  There may be a better way and/or solvent.
Yann Guidon / YGDES wrote 02/18/2017 at 14:45 point
that's an interesting idea... solvent...
esot.eric wrote 02/21/2017 at 08:08 point
Indeed!
Long ago I had surprisingly good luck with old ribbons... what must've been sitting around for years if not decades still functioning. I bet solvent would be even better.
