The third print of the Apple Ecosystem Unified Input Chassis came out great! There are just a few important improvement opportunities, and I've already implemented them.
1. The Left Side Cable Access port was adjusted to print at an angle, using the 45 degree uneven hexagon style that I used for the decorative 'speed holes' on the bottom. This should let it print without supports!
2. The Track Pad Lock Block needed two points of contact with the main body to hold it straight. This means I need supports again, but I'm trying something new... built-in support!
3. Cable Management channels had slop due to overhang, so I rotated then 45 degrees.
Looking Good, but I'm all out of white filament at the moment.
