Hackaday.io Hackaday.io
Sign up Log in
non rotational (linear) stirling generator
This generator eliminates the need for inefficient mechanical transference of a sterling engines output to produce electricity
rbbrawnerrbbrawner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.4k views
2 comments
49 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
  • Official Hackaday Prize Entry
View Gallery
1.4k
2
49
8
Team (1)
  • rbbrawnerrbbrawner
Join this project's team
  • video
sterling engine efficient power generation thermal generator
Related lists
2014 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2014 Hackaday Prize
This project is submitted for
This project was created on 07/12/2014 and last updated 12 years ago.
Description
Dual heat expansion tanks(1) absorb heat energy and once a tank has reached the optimal pressure the solenoid valve(2) opens releasing the pressure to the expansion side while the apposing solenoid valve opens to vent/intake air. This action moves the internal magnetic piston through the copper coil(3) producing electricity.
Project Logs
Collapse
  • Calculations have begun
    rbbrawner • 08/08/2014 at 12:47 • 0 comments
    Started doing some math though the cycle will not be as fast as I originally thought
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
rbbrawner wrote 07/14/2014 at 22:12 • point
Think of a Y connection that opens to both the thermal collector and to ambient air. The initial release is to the generator followed by a vent of the hot air pulling in ambient cooler air (venturi effect). Thermal dynamics was not my best subject.... but my trig and knowledge of friction and mechanical dynamics are putting this as one of the highest output sterling (power) generators I can think of. Thanks for the interest!
Mike Forhan wrote 07/14/2014 at 20:17 • point
Since you are using 2 solenoids to enable the piston, how do you plan on getting net positive energy output? Have you done any calculations to determine the possible output?
I needed a vacuum pump for making some FRP parts, so I modded an aquarium air pump for that.
Project Owner Contributor
Aquarium Air Pump -> Vacuum
christophChristoph
The Hosemaster has many hoses including Air Hose Fittings which are suitable for Diy and heavy duty industrial applications.
5 Important Types Of Hoses - The Hosemaster
thehosemasterthehosemaster
Mechs are not viable, nor cheap, so I will try to design and build one alone anyway.
DIY Mech or Exoskeleton suit.
fulanodetailFulanoDetail
a tutorial on making glass-sealed noble gas tubes.
Make Noble Gas Glass-sealed Tubes in Your Home
simon-liuSimon Liu
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "non rotational (linear) stirling generator", please tell us the reason.
Send message
Remove Member
