Construction
A project log for Stuart Conner's Simple TMS9995 board build
keithKeith 10/02/2022 at 11:380 Comments
2020-04-25
Soldered on the simple 9995 board:
2022
2022-09-30
2022-10-15
2022-10-15
2022-11-21
TMS9902 fitted, but no serial I/O seen.
2022-11-24
EEPROM socket pin 27 changed from /WR to VCC. May have been corrupted, so I reprogrammed it. Got partly garbage characters with the common 9600-8-N-1 setting. Followed web page and set it to 9600-7-E-2 setting. Success, the sign-on message appeared.
2022-11-26
115200 is the highest baud rate. It copes with a low character rate, and accepted my typing
 10  PRINT "HELLO WORLD! "
 20  GOTO 10
but when I copied and pasted the same text, I got
0 RT"EOWRD" 0GT 0
which shows it cannot process incoming text at that rate.
At 9600 baud, I got
10  PRT "HELO WORLD "
which is a little better. At 4800 baud:
0  GOTO 0
At 1200 baud:
 10  PRINT "HELLO ORLD! "
2  GOTO 10
Even at 300 baud, characters are missed. It clearly needs flow control, but RTS and CTS are joined at the UART.
Stuart Conner said that most terminal programs let you set inter-character and inter-line transmit delays. However, the 300 baud rate slows the character rate to around 30 characters per second which is 33 ms each. That should be plenty of time.
Characters are missing in the middle of lines, when the CPU has nothing to do but put them in a buffer. It is not due to the CPU taking a long time to parse a line of BASIC.
The software solution would be to modify the firmware to have interrupt-driven serial input, so that characters would be buffered as fast as they came in, but it will take me a long time to modify code for a CPU I have no experience of. I'd have to add CTS/RTS handshaking but FTDI USB cables don't stop sending bytes until up to 3 bytes after being told to stop.
My favoured solution would be to get the CPU talking to an FTDI USB FIFO module. No baud rate hassles, not RS232 voltages and buffers, and dead easy to interface.
