A simple 555 timer that blinks the test result strip
BOM
R1, R4 100 Ohm
R3 150 Ohm
R2 390k Ohm
C1 1uF
D1, D2 RED LED
U1 LMC555 timer
The 555 timer has a chamfer to indicate the side of thr first pin.
View project log
Are you planning on releasing the board files for this?
woops, thought I had posted the github link here, it's in this repo https://github.com/davedarko/Simple-Add-ons-SAO
Do you consider replacing the plug on the back with typec?
hey sunny, I haven't seen any simple add-ons for badges that use USB-C yet. If I'd make this portable, I would probably just use a coin cell instead.
endevor100
icstation
LouD
Alex
Yes, delete it Cancel
You are about to report the project "COVID-19 | SAO Simple Add-on", please tell us the reason.
