Hackaday.io Hackaday.io
Sign up Log in
Innovative Idea Award
creating a trophy that represents innovation and creativity, this is purely designed to be artistic, and are in no way, shape or form useful
foulummosegaardfoulum.mosegaard
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
0 comments
0 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
Public Chat
0
0
0
Team (1)
  • foulummosegaardfoulum.mosegaard
Join this project's team
  • Youtube
completed project
hardware
This project was created on 10/03/2022 and last updated 3 年前.
Description
I firstly used blender to sketch a few ideas of how i wanted the trophy to look before i chose a final design.
when i had a sketch, i started creating the model around an encasting for the power source (9V bat), PCB and wires. eventually i reached a point where i had to 3D-Print it.
Then came the centerpiece, putting a little lazercut piece of wood covered in parralel SMD LED´s, hovering on the inside of a bulb. this was a major pain, as i firstly had to open and empty the inside of a lightbulb, without it exploding... this was the most expensive part of the project.
after the sign was mounted and epoxyéd stuck to the inside, the bulb was then attached to the 3D-Print, and this was the first time the LED´s was tested on the basic 555 breathing LED circuit.
Finally i felt confident assembling the entire thing, with a very pleasing final resoult.
Details
Files
ZBC Trophy.zip
Bits, bobs and the trophy
x-zip-compressed - 19.19 MB - 10/12/2022 at 06:46
Download
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Designing a compact coaxial gearbox that can fit in the neck of a 3D printed motorized lamp.
Project Owner Contributor
Making a Coaxial Gearbox for a Rotating Lamp
marciotmarciot
When the Internet is up and running, the notifier displays a blue light and when the Internet is down it goes red.
Destiny Internet Ghost - Internet Notifier
hulkHulk
A 3D-printed zoetrope ring spins on a record player, with WS2812 LEDs ATtiny85 strobing images to create the illusion of motion
Spinning Zoetrope with LED Strobe
markus-loefflerMarkus Loeffler
A Wand-themed Attiny13A Based Flash Light
Wand of Illumination
arnov-sharmaArnov Sharma
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Innovative Idea Award", please tell us the reason.
Send message
Remove Member
