In this tutorial, we are going to control 1 watt RGB LED using the ESP8266 ESP01 WiFi module. You can use any Wi-Fi-enabled device to access the web interface to control this RGB LED. Watch the video at the bottom of this page.
Here we have created a simple webpage with esp8266 which has different color codes each color have a unique code for RGB (Red, Green & Blue) LED. RBG LED we used here is common Anode which means +ve of all LED's is common and LED glows from dark to light depending on the value received via webpage by the user.
PCBWay commits to meeting the needs of its customers from different industries in terms of quality, delivery, cost-effectiveness, and any other demanding requests. As one of the most experienced PCB manufacturers in China. They have an open source community, people can share their design projects with each other. Moreover, every time people place an order for your board, PCBWay will donate 10% of the cost of PCB to you, for your contribution to the Open Source Community.
Hardware Required
You will require the following hardware to make RGB LED.
S: NoValueQty
1ESP-01  WiFi module1
21W RGB LED1
310Ω Resistance1
4ASM1117 3.3v  (or any 3.3v voltage source)1
5USB to TTL converter (for programming esp-01)1
6Momentary push button (optional)
7Android / Apple / Windows  Phone or any WiFi enabled Laptop / Desktop (to control RGB LED)-
8Jumper wires and a breadboard1
RGB LED Circuit
RGB LED Code
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
const char *ssid = "RGB";
//Uncomment below line if you wish to set a password for ESP wifi network...
// const char *password = "87654321";
const byte DNS_PORT = 53;
IPAddress apIP(192, 168, 1, 1);   //IP address of your ESP DNSServer dnsServer;
ESP8266WebServer webServer(80);
//Webpage html Code
String webpage = ""
"<!DOCTYPE html><html><head><title>RGB control eTechPath.com</title><meta name='mobile-web-app-capable' content='yes' />"
"<meta name='viewport' content='width=device-width' /></head><body style='margin: 0px; padding: 0px;'>"
"<canvas id='colorspace'></canvas>"
"</body>"
"<script type='text/javascript'>"
"(function () {"
" var canvas = document.getElementById('colorspace');"
" var ctx = canvas.getContext('2d');"
" function drawCanvas() {"
" var colours = ctx.createLinearGradient(0, 0, window.innerWidth, 0);"
" for(var i=0; i <= 360; i+=10) {"
" colours.addColorStop(i/360, 'hsl(' + i + ', 100%, 50%)');"
" ctx.fillStyle = colours;"
" ctx.fillRect(0, 0, window.innerWidth, window.innerHeight);"
" var luminance = ctx.createLinearGradient(0, 0, 0, ctx.canvas.height);"
" luminance.addColorStop(0, '#ffffff');"
" luminance.addColorStop(0.05, '#ffffff');"
" luminance.addColorStop(0.5, 'rgba(0,0,0,0)');"
" luminance.addColorStop(0.95, '#000000');"
" luminance.addColorStop(1, '#000000');"
" ctx.fillStyle = luminance;"
" ctx.fillRect(0, 0, ctx.canvas.width, ctx.canvas.height);"
" var eventLocked = false;"
" function handleEvent(clientX, clientY) {"
" if(eventLocked) {"
" return;"
" function colourCorrect(v) {"
" return Math.round(1023-(v*v)/64);"
" var data = ctx.getImageData(clientX, clientY, 1, 1).data;"
" var params = ["
" 'r=' + colourCorrect(data[0]),"
" 'g=' + colourCorrect(data[1]),"
" 'b=' + colourCorrect(data[2])"
" ].join('&');"
" var req = new XMLHttpRequest();"
" req.open('POST', '?' + params, true);"
" req.send();"
" eventLocked = true;"
" req.onreadystatechange = function() {"
" if(req.readyState == 4) {"
" eventLocked = false;"
" canvas.addEventListener('click', function(event) {"
" handleEvent(event.clientX, event.clientY, true);"
" }, false);"
" canvas.addEventListener('touchmove', function(event){"
" handleEvent(event.touches[0].clientX, event.touches[0].clientY);"
"}, false);"
" function resizeCanvas() {"
" canvas.width = window.innerWidth;"
" canvas.height = window.innerHeight;"
" drawCanvas();"
" window.addEventListener('resize',...
