Max's NeoPixel Sign
A web-enabled digital sign that uses individually addressable RGB LEDs and a NodeMCU microcontroller. Display is configurable via JSON.
This project uses a NodeMCU microcontroller to render a "slideshow" of static images using several rows of individually addressable RGB LEDs. At startup, the NodeMCU module connects to Wifi and downloads the images in JSON format from github pages. There is also a separate web application which can be used to create / draw new images, and configure the slideshow settings.
New "pixel art" images can be created using the following web interface: https://digitalsoup.org/app/default/max-sign
config.json
This is the global configuration file which dictates what images will be displayed, in what order, and with what transition. It is served up by Github Pages. http://tinyiot.digitalsoup.org/PixelArt/config.json
JavaScript Object Notation (JSON) - 6.48 kB - 10/05/2022 at 14:58
Download
halloween.json
This is a sample image file. It is served up by Github Pages. http://tinyiot.digitalsoup.org/PixelArt/images/halloween.json
JavaScript Object Notation (JSON) - 8.31 kB - 10/05/2022 at 14:58
Download
Image Slideshow.mp4
Sample Image Slideshow
MPEG-4 Video - 17.39 MB - 10/05/2022 at 14:19
Download
Fire Test.mp4
This was a test to see if I could render a dynamically generated pixel-art "fire".
MPEG-4 Video - 7.23 MB - 10/05/2022 at 14:17
Download
