Navigation
Prior Reading
Contents
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
Preface
[2024 - Jan 13]
This project started in an attempt to be a no-frills mount for a set of #Tetrinsic's [gd0041] which soon pivoted to conceptualize a cuboid-shaped input device.
kelvinA
[03:15]Me In The Past... I've done it. This is no alternate dimension. This new Tetrinsic design might actually have "all the benefits and none of the drawbacks", price and build time nonwithstanding. I've just had to increase the square to 92mm and move Thumb1 up 4mm.
I think a grey would look the most calming without potentially clashing with a custom coloured Tetrinsic. I could get more exotic with the surface though, such as using an 8x8 LED matrix or a sparkly vinyl (see below). The OLED used in TimerSpy doesn't fit though. I also wonder if I should have both cutouts use the same material as it could improve consistency.
The whole bottom of the cutout is on the same plane.
Oh yeahhhhh... that's the professional concept render vibe right there. Now I just need to wait for the print to finish to find out if an ergonomic solution exists.
I've moved everything right to the edge. Speaking of the edge, 3.3mm is barely enough space around the fingers and I've increased it to 4.5mm.
actually actually it's not too bad...
yeah yeah I can accept that art-deco like look
yeaaaa the circles have more of an engine look, but it does look lighter.
For the fingers tho, it starts to feel disorienting with multiple different straight line angles. I'll keep with the circles.
I'll also get rid of the fillets closest to the motors (original on left, adjusted on right) because it looks more continuous.
I think this is aesthetically acceptable. It's not as ice-cool as the "advanced looking metasurface chiselled into a solid block" of the non-motor render, but it does get appreciably close.
😭This cutout looks so beautiful and simplistic, unlike the cutout I did for Tetrinsic 1st Generation.
Wait a second. that 20mm dimension doesn't go all the way to the top. What is this extra block here for then?
Even accounting for the gap between the board and the magnet, there's plenty of space in 20mm! Ok I'll start fixing this.
but ergonomics said:
This is 4 degrees, but I'm feeling the concept-print-before-the-previous one and maybe it's even less than that. The solution is close to 0 degrees but isn't 0.
2 degrees might not be too noticable. And it's not like keyboards or controllers are visually aligned either, nor will I see this side when actually typing. A counter point though is that an increased angle increases the likelyhood of a Finger2->motor collision.
I've also increased the main angle from 10 to 12 degrees and decreased the main square from 100 to 95mm. I think all those changes make the design look sleeker.
I've brought in the Tetrinsic Gen 3X1 concept into TestCut. It's probably because of the green, but man this looks like some kind of alien tech, such as Sonic Frontiers' main bosses when they go into their second stage:
The cuboid is also larger now; it's a 100mm square prism.
Black bars between Tetrinsics looks more uniform, but I'd be OK with either:
Thanks, though I wasn't expecting this relative surge of interest just because I changed the hover description to "A cuboid input device." I just thought that I shouldn't expect prior knowledge on my other projects, and so made it shorter and to-the-point.
