Hackaday.io Hackaday.io
Sign up Log in
Let it Snow
Snowfall on Linux console
dumitrustamadumitru.stama
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4 comments
5 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
783
4
5
2
Team (1)
  • dumitrustamadumitru.stama
Join this project's team
  • Project files on GitHUB
  • Youtube simulation
Software
ongoing project
linux framebuffer amd64 rdrand simulation
This project is submitted for
  • The 1kB Challenge
This project was created on 12/04/2016 and last updated 9 years ago.
Description
I never knew a full HD screen has soooo many pixels. I knew the actual numbers but to fill it pixel by pixel it's a hard job ! Remember this next time you play your favourite game at 60fps, your video card is a true hero, a miracle of recent years technology. My project sets up a snowfall simulation using the frame buffer in Linux console mode. The snowflakes collide with each other and other objects and pile up in time. There is a Youtube video linked on this page where you can actually see it in action for ~30 minutes. I used AMD64 assembly and "rdrand" instruction so you need a fairly recent processor to replicate it. I know, I know, NSA and other agencies have supposedly back-doored this instruction but I am not using it for cryptography :). Project is not yet optimised at algorithm level but it's already 1000 bytes in binary form (ELF headers don't count according to HAD 1KB contest rules since they don't add functionality)
Files
This is how it looks like at full resolution
image/png - 34.47 kB - 12/04/2016 at 17:53
Preview
Project Logs
Collapse
  • Second screenshot
    dumitru.stama • 12/11/2016 at 03:14 • 2 comments
    Here is another screenshot after letting the program run on the TV for one night.
    Almost there... :)
  • Screenshot
    dumitru.stama • 12/04/2016 at 17:50 • 0 comments
    Here is how it looks like in FullHD (the screenshot is in the files section).
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Eric Hertz wrote 12/08/2016 at 15:43 • point
Hah, cool! Got some ideas brewing from this, thanks :)
Yann Guidon / YGDES wrote 12/04/2016 at 19:26 • point
This brings back the nostalgia of the old xsnow program...
Next version : add pines and let Santa slide on his sleg :-)
Furthermore, no need of a special instruction to generate (pseudo-)random numbers. I think there is an "entropy pool" that will limit the rate of generated numbers to preserve "randomness" but you don't need that. A simple LFSR works. But if you are after code size, check the documentation carefully about the rate of execution of this opcode.
dumitru.stama wrote 12/04/2016 at 19:46 • point
:) I don't think there is enough space for that but I still have to optimize the implementation. Maybe I can squeeze a few hundred bytes out and put some sprites.
I choose rdrand because it spits out a random number (pseudo) in 4 bytes and it simplifies things a lot
Yann Guidon / YGDES wrote 12/04/2016 at 20:24 • point
By next version, I mean for a larger one. Though the xsnow sprites are low-res and easily compressible and could add some bonus points in the contest :-)
The 2015 Hackaday Prize
Augmented Reality Cubic Kartoska Space Exploration Simulation. Totally Safe.
Project Owner Contributor
Very Expensive Tool with C++ and Javascript
skyberrysskyberrys
Hackaday Prize 2020
Built with the 65C02 and the Parallax Propeller. Retro II is open source and utilizes off the shelf parts to recreate the magic of the 80's.
Retro II - An Apple II Compatible Computer
jon-thomassonJon Thomasson
Learn circuit simulation with LTspice or NGSpice. Enter a schematic, simulate, view the results, and make simulation models.
Circuit Sim with SPICE @ 2015 SuperConference
tom-andersonTom Anderson
Warning! No Rocket involved! Collaborative Open Art Project.
1050mph Virtual Rocket Camera
frankstripodfrankstripod
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Let it Snow", please tell us the reason.
Send message
Remove Member
