UpdateSTLfiles&arrangements.zip
*SmallGearGeneratorShaftLinkerPerfectFit (There was an error in the diameter of the hole for the motor 31ZY shaft fit) It is fixed.<br>*It has been added options for a new dc motor Uxcell RF-500TB-ShaftLinker<br>*Another optional gearbox system with range 3x1 for less wind option making the load less despite less watts.
Zip Archive - 1.05 MB - 10/22/2022 at 23:02
Download
ExtendExtensor.stl
A new stl files has been updated with the name of ExtendExtensor.stl that consist of a turbine extension unit that can be linked with other extension units, so the turbine diameter can be extended more in case there is few wind available and you are using the 2 generators in the device.
Standard Tesselated Geometry - 45.59 kB - 10/15/2022 at 19:20
Download
3dPicsAssemblyStepByStep.zip
Zip Archive - 2.48 MB - 10/12/2022 at 00:14
Download
