I wanna be able to turn off the power to the amplifier, so I drilled a hole in the case and added a switch
I also want a power indicator so I don't forget to turn off the power to the amplifier, so I added an LED next to the volume knob.
A project log for Microkorg speaker mod
The microkorg is a wonderful machine. One of the cons is the lack of internal speakers, but that can be changed!
