Channel selection
A project log for Wireless ETTL flash conversion
Convert a vintage flash to wireless with full ETTL
lion-mclionheadlion mclionhead 12/20/2022 at 19:330 Comments
This feature definitely required debugging headers.  The trick with channel selection is there aren't enough clockcycles to poll the button pin or increment a tick counter.  It needs its own loop inside an interrupt handler which runs when the button is pressed.
