gCore uses the ESP32-WROVER-E module which has dual-CPU revision 3 ESP32 silicon, 16 MB Flash memory and 8 MB PSRAM.
High Performance LCD Capacitive Touchscreen Display
TFT 480x320 pixel LCD Display using ILI9488 controller configured to use a 8-bit parallel interface.  The parallel interface is driven by a shift register and other logic connected to the native ESP32 VSPI GPIO pins.  This allows code on the ESP32 to drive the SPI bus at the maximum 80 MHz (faster than the ILI9488 allows in SPI mode).   Bodmer's fantastic TFT_eSPI library has been ported and screams on gCore.  A FT6236 touchscreen controller allows up to two point touch detection.
Full Power Path Li-Ion Charger
gCore is powered by a 3.7V Li-Ion or LiPo battery (typ 500-4400 mA) or USB.  The battery connection uses the standard Adafruit/Sparkfun JST connector.  A Microchip MCP73871 charge controller provides a separate path for battery charging and for board power.  This ensures it can accurately determine charge completion and allow board power to be sourced from USB only when possible or shared between USB and battery power when necessary.  I wanted a full power path charging circuit because I've seen battery life problems with the dev boards that simply hang the board load directly on the battery connection with the both powered by the same charge controller output.  A jumper allows either a 500 mA or 1A maximum charge current selection.
Soft Power Control / RTC
gCore contains a Silicon Labs EFM8SB20F32 8-bit microcontroller that acts as a power manager (PMIC), provides a real-time clock (RTC) with alarm and NVRAM/NVFlash, and board control/monitoring control.  The ESP32 communicates with it over I2C.
4-bit Micro-SD Card
All four bits of the Micro-SD Card connector are connected to the ESP32 allowing high performance 4-bit SD-mode access.  I've seen up to a 5.5X performance increase for large writes over the typical SPI-based SD Card interface.  The GPIO signals are also available on SMT pads if the SD Card is not being used.
USB Interface
A Silicon Labs CP2102N USB UART is connected to the ESP32 serial port and includes the traditional auto-programming (DTR/RTS) circuitry to put the ESP32 into boot mode.
Expansion Port
Unused ESP32 GPIO plus the GPIO used for the I2C interface are brought out to a connector along with both switched and un-switched 3.3V regulated outputs, a switched version of the battery rail, and other signals such as USB power and the power button signals for external circuits.   The I2C interface is also available on a Qwiic compatible connector for easy connection to peripheral devices from Sparkfun, Adafruit and others.
Software Support
gCore can be programmed in C/C++ using either the Arduino or Espressif IDF environments or in Micropython with the ESP32 Micropython or LVGL lv_micropython ports.  I've written an Arduino library for the EFM8-based functions, ported Bodmer's eSPI_TFT library and provide a whole bunch of demos in the Arduino library or in other github repositories.
