Part-DB 1.1.0 - SAML Support
A project log for Part-DB - Open Source inventory software
Part-DB is an Open-Source inventory management system for your electronic components. It is installed on a web server and so can be accessed
jan-bJan B. 03/09/2023 at 15:230 Comments
With version 1.1.0 Part-DB now supports Single-Sign-On via SAML. Using a identity provider server like keycloak you can connect Part-DB to your central user managment, which should be especially useful for larger organizations like companies, universities or makerspaces.
See https://docs.part-db.de/installation/saml_sso.html for more info
