We upgraded the hardware to use T113-S4, which has built-in 256M DDR3 memory and added a 1GHz 64bit C906 RISC-V processor, which can run freertos/Nuttx.
We also upgraded the wifi module to the WIFI6 version of AIC8800D80, which greatly improved the wireless speed.
When the wifi6 signal quality is high, the speed of iperf3 -c is around 270M and the speed of iperf3 -s is around 300M.
Of course, a 512MB SD Nand storage chip is also installed for it, so that the system and programs can be solidified inside.
ElecLab
HI, our code is not yet organized, and we use the uboot of Tina5.0. We have used buildroot2024 and linux6.12 lts on T113-S3, but have not yet fully tested.
U-Boot 2018.07 (Dec 21 2024 - 12:12:24 +0800) Allwinner Technology
[00.421]CPU: Allwinner Family
[00.424]Model: sun8iw20
[00.426]DRAM: 256 MiB
[00.429]Relocation Offset is: 0cebf000
[00.456]secure enable bit: 0
E/TC:0 tee_read_fdt:426 fine node /firmware/optee failed with FDT_ERR_NOTFOUND
[00.469]smc_tee_inform_fdt failed with: ffff0000
[00.475]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.481]gic: sec monitor mode
sunxi flash map init
[00.486]flash init start
[00.488]workmode = 0,storage type = 1
Thanks for your answer. I can't download Tina Linux from America :( , Do you plan share your binaries? Or you know how can I download Tina 5 from America?
Hello I've already built a T113-S4 board, almost all works fine, but audio decoder doesn't work. I think that mainline u-boot doesn't configure well the clocks. Which u-boot are you using?
