• 1
    Using the arduino in serial bridge mode
    Take a short jumper wire or small piece of wire and solder it to the RST and GND pin on the arduino
  • 2
    Soldering the Male-Male breadboard jumpers
    Solder a wire to each of the following pins on the arduino
    TX
    RX
    VIN
    GND
  • 3
    Using a empty plastic drink bottle for some insulation
    Take a old sprite or coke bottle (450ml one)
    Cut it so it is 2CM longer on each side of the arduino
    Make sure it is completely dry
    Put the arduino inside the bottle
    Use a hot air station or flame to shrink the bottle arround the arduino
    (Anything can be used or could be left un insulated if needed)
