DIY ESP8266 Led Matrix Clock Kit
Back to overview
Entry-level DIY kit, designed as fun activity one can complete in one evening
Shourov Paul wrote 09/19/2023 at 17:17 point
How i can change the time formate 24 hours to 12 hours?
Robert White wrote 06/10/2023 at 09:27 point
Thank you that's a great help
Robert White wrote 06/08/2023 at 21:59 point
Hi Arantansi
Built the clock and think its great. I have two questions
1) How can I limit the maximum brightness of the display?
2)How can I handle the change to/from daylight saving without changing the timezone and reload the program in the clock?
Thanks
Regards
Robert
andriy.malyshenko wrote 06/08/2023 at 22:58 point
Hey Robert
1. You're looking for this line: https://github.com/anabolyc/esp-led-matrix-clock/blob/master/firmware/esp8266-led-clock/src/renderer/AutoBrightness.h#LL8C9-L8C30
2. When it will synchronize the clock it will take into account DST. That's the whole beauty of having internet connected clock :)
dekinter wrote 04/25/2023 at 21:39 point
I cannot find the clock on my network after setup and would like to know how to go back to the AP start
Serge Ménard wrote 04/11/2023 at 20:10 point
Following instruction above to connect to connect to ESP_209581, I have an ip address of 192.168.4.2. Using the browser on my phone with that address, I am returned with an error code err_connection_timed_out or err_connection_refused. Any idea ?
andriy.malyshenko wrote 04/15/2023 at 21:13 point
Usually you will get redirected by your phone automatically, I'm not sure it should respond on the root address. I will double check with my clock and get back to you
Serge Ménard wrote 04/15/2023 at 21:17 point
OK. When trying to access the clock from my PC, not my phone, I get 192.168.4.1. That worked just fine. Thanks for your reply.
aratansi wrote 04/01/2023 at 19:55 point
Thanks
aratansi wrote 04/01/2023 at 12:45 point
How to configure for 12h mode
andriy.malyshenko wrote 04/01/2023 at 19:24 point
please remove this line from platformio.ini
-D SCREEN_FORMAT24H
