Hackaday.io Hackaday.io
Sign up Log in
DJI FPV - Battery Breakout Mod [4]: Battery Packs
Here I would like to present some ideas and solutions for self-made battery packs.
aircruiserAirCruiser
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
4.3k views
3 comments
30 followers
  • Description
  • Details
  • Files 11
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
Public Chat
4.3k
3
30
21
Team (1)
  • aircruiserAirCruiser
Join this project's team
  • YouTube (AirCruiser)
ongoing project
DJI FPV DJI FPV drone Battery LiPo LiIon 6S Quadcopter
Related lists
DJI FPV bat
battery hacks
This project was created on 11/11/2022 and last updated 4 years ago.
Description
I have developed some simple but functional solutions to use normal 18650 and 21700 LiIon cells as well as the original DJI LiPos for my breakout mod. Here I want to share the STL files with you and show you how to assemble them. If you develop other solutions, feel free to share them with the community :) Caution: Working (and especially soldering) with LiPo and LiIon cells is dangerous. Short circuits can lead to fires and even explosions. This is just a brief overview. Inform yourself carefully before soldering battery cells. Everything is done at your own risk. YouTube: https://www.youtube.com/@AirCruiserFPV Discord: https://discord.gg/Yfan8F3epY Mail: aircruiserfpv+hackaday@gmail.com Thingiverse: https://www.thingiverse.com/thing:5716006
Details
Files
BatteryCase_18650_Cover (New).stl
Cover for the 18650 Battery Case
Standard Tesselated Geometry - 24.50 kB - 02/28/2023 at 21:47
Download
Landing_Gear.stl
The "shoes" of the battery cases. Highly recommended to be printed with TPU (or other soft filaments).
Standard Tesselated Geometry - 11.02 kB - 01/05/2023 at 22:41
Download
BatteryCase_18650.stl
Case for 18650 LiIon cells
Standard Tesselated Geometry - 480.36 kB - 01/05/2023 at 22:41
Download
BatteryCase_DJI.stl
Case for original DJI LiPo cells
Standard Tesselated Geometry - 369.81 kB - 01/05/2023 at 22:41
Download
BatteryCase_21700_Bottom.stl
Bottom cover for the 21700 LiIon cases
Standard Tesselated Geometry - 88.95 kB - 01/05/2023 at 22:40
Download
View all 11 files
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
abristotti wrote 08/19/2024 at 18:34 • point
I also need to know how to do that without looking the BMS
werty1st wrote 06/11/2024 at 18:44 • point
How did you manage not to lock the BMS during your modifications?
Did you always provide enough voltage for the BMS to think the battery is not deep discharged?
How do you charge the batteries?
Is a locked BMS still useable for you mod?
I have an original FPV battery thats locked and can't charge the normal way. Maybe I can use them as a replacement if the cells in the other batteries start to fail. But I don't know how to swap them without triggering the BMS lock.
Steve Casanova wrote 01/27/2024 at 18:11 • point
Did you try to hack the drone's firmware?
https://i.imgur.com/mQOWKIv.png
Proper Li-Ion battery monitor, protector, and balancer with diagnostics, and for an affordable price.
Project Owner Contributor
The Fully Automated BMS
zoZoé
LIR1220 Li-Ion Battery Charger
LIR1220 Charger Stick
stefan-wagnerStefan Wagner
AutoRechargableBattery
aosoresmoranteaosoresmorante
2002 Suzuki SV650 electric conversion
2002 Suzuki SV650e
nealNeal
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DJI FPV - Battery Breakout Mod [4]: Battery Packs", please tell us the reason.
Send message
Remove Member
