Z80 on TV via AV
11/27/2022 at 01:47 • 0 comments![]()
One day I shall teach you how to do this only using a Z80 CPU without any special chip...
#z80 #tv
ZiLOG Z80 - curiosities
11/27/2022 at 01:41 • 0 comments![]()
Z80 CPU - Have you ever seen one?
Curiosities here:Release:
- May 1976 by ZiLOG.
Number of transistors:
- ZiLOG Z80 CPU: 8500.
- Intel 8085 CPU: 6500.
- Intel 8080 CPU: 4500.
Instructions:
- 158 different "instruction types" (FUNCTIONS) including all 78 of the Intel 8080A CPU [datasheet].
- Intel 8080 CPU instructions: 256.
- 196 fully compatible with Z80;
- 58 DIFFERENT intructions opcodes;
- 2 UNCOMPATIBLE FUNCTIONS.
- Z80 compatibility: 76,56%.
- Z80 CPU:
- Documented instructions: 694;
- Undocumented instructions: 710;
- Total instructions: 1404.
My model:
- Part No. Z84C0020PEC.
- "84C00" means "CMOS technology".
- "20" means "20MHz max frequency".
- "PEC" means "unfilled Poly(ethylene carbonate)" - therefore: Temperature range: Extended industrial: −40 °C to 85 °C.
- "1822 GZ" = UNKNOWN DATA.
My Instagram: https://www.instagram.com/herr_marr/
Erick M.B. d. S.
