Adding a logo
A project log for Squeak: GPS pet tracker
Squeak is a LoRaWAN GPS pet tracker with a very long battery life. It allows you to ask your pets to share their location
mihaicuciucmihai.cuciuc • 12/05/2022 at 06:16•0 Comments
I could not resist the temptation to add a logo to the case. Also made the case a bit taller to remove the humps for the GPS antenna and temperature sensor.
