PokyPow is your companion for conveniently powering on, off, resetting, and remotely monitoring your PC’s power state. This simple ESP32-based board gives you the power of a system administrator without purchasing enterprise-grade solutions.
Using standard PC power and USB headers, PokyPow makes your computer another device on your Home Assistant network. And since PokyPow uses standard ESPHome firmware, you can tweak the configuration or vet the code to ensure its trustworthiness. Whether you’re trying to save money on energy or want to have your gaming rig all fired up by the time you step in the door, PokyPow lets you control your PC like never before.
Andrej
hebel23
Jean Alinei
Peter McCloud
Hi!
Cool, but how and what do you attach it to? Will this device have a case?
