Flite Test Gremlin FPV Drone
Using an old frame I bought a while back and the newer parts on the Flite Test website to build my very first FPV drone
Public Chat
I 3D printed some skids and an FC adapter(Glow in the dark) for this build. Parts listed below: FT Gremlin 1104 5400kv Motor Link: https://store.flitetest.com/ft-gremlin-1104-5400kv-motor/ GHF411 PRO-BMI 40A Toothpick F4 2-6S AIO BRUSHLESS Flight Controller Link: https://store.flitetest.com/ghf411-pro-bmi-40a-toothpick-f4-2-6s-aio-brushless-flight-controller/ LEMON RX DSMP (DSMX COMPATIBLE) DIVERSITY SATELLITE Link: https://store.flitetest.com/lemon-rx-dsmp-dsmx-compatible-diversity-satellite/ Caddx Ant AIO FPV Camera Link: https://store.flitetest.com/caddx-ant-aio-fpv-camera/
     UPDATE
The original AIO to 20x20 design was too large and was the wrong orientation for this build and won't work so I designed one with the correct orientation and small enough to fit the flight controller.
AIO TO 20X20 MASTER1.stl
The AIO adapter used in this build
Standard Tesselated Geometry - 74.98 kB - 01/10/2023 at 14:25
Download
skids_11xx_9mm.stl
Skids I used in this build
Standard Tesselated Geometry - 170.69 kB - 11/14/2022 at 21:50
Download
  • 1 × Caddx Ant AIO FPV Camera FPV Camera
  • 1 × GHF411 PRO-BMI 40A Toothpick F4 2-6S AIO BRUSHLESS Flight Controller Flight Controller
  • 4 × FT Gremlin 1104 5400kv Motor Motors
  • 1 × LEMON RX DSMP (DSMX COMPATIBLE) DIVERSITY SATELLITE Receiver
  • 4 × 2.3 inch BabyHawk Propellers Propellers
  • Upadate on adapter design
    Jibril • 01/10/2023 at 15:03 • 0 comments
        UPDATE
View project log
