Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Mushroom Growing Control System
Industrial control in a humid environment
Capt. Flatus O'FlahertyCapt. Flatus O'Flaherty
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.7k views
6 comments
46 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 9
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
2.7k
6
46
39
Team (2)
  • Capt. Flatus O'FlahertyCapt. Flatus O'Flaherty
  • lee.hughes2011lee.hughes2011
Join this project's team
  • Github
  • Website
ongoing project
MusHrooms
Related lists
Interessante
Coisas interessantes
This project was created on 11/16/2022 and last updated a month ago.
Description
Growing mushrooms in shipping containers requires good control of humidity, temperature, particle contamination and C02 levels. This initial container has been set up on the Island of Anglesey (Ynys Mon), North Wales to test the custom built control system and evaluate the viability of growing gourmet mushrooms in shipping containers.
If anybody wants to support any of our projects, check out our Amazon Wishlist here: https://www.amazon.co.uk/hz/wishlist/ls/3AW6R7V5BVU3R?ref_=wl_share
Patreon donations can be made here: patreon.com/Goat_Industries
Files
sensirion_co2_and_plantower_particulate_sensor_06.ino
ino - 14.11 kB - 11/19/2022 at 20:27
Download
Mushroom_control_standard_ESP32_01.pcb
pcb - 461.50 kB - 11/16/2022 at 20:18
Download
Mushroom_control_standard_ESP32_01_GERBERS.zip
Zip Archive - 123.74 kB - 11/16/2022 at 20:17
Download
Project Logs
Collapse
  • Shrinking the 20 ft container to 3 ft
    Capt. Flatus O'Flaherty • 12/18/2022 at 18:06 • 0 comments
    The recent cold weather sent our electricity bill into the ionosphere so we put an insulated wall inside the container to effectively shrink the fruiting room to 3 ft deep. Fortunately, we've still got the clean air fan, a LED striplight and 240 v power plugs. Also, by placing the LoRa antenna up against the air filter, the mushrooms were still able to communicate with the outside world.
  • Neighborhood Smog gets into the Container
    Capt. Flatus O'Flaherty • 12/12/2022 at 09:41 • 0 comments
    A few days ago, looking at these data graphs, we noticed that Co2 levels would rise to about 700 ppm and then flatten off, holding steady at this value. This is NOT GOOD for the mushrooms as it seems to indicate that they stop producing CO" when the atmosphere reaches this level and presumably stop growing as well. Fortunately, there is a fan in the system, which we then started to use and monitor the results. Since the outside temperature is about 1 degrees C on average at the moment, it's important to minimise the airflow into the container so that there is just enough airflow to moderate the CO2 levels and no more as otherwise heating costs would escalate. We're keeping a careful watch on electricity consumption and will need to make a calculation to assess how many mushroom blocks are required in one batch to justify the heating costs or if a false wall should be installed in the container for the testing stage.
    Data from the mushroom container can be seen live at https://www.goatindustries.co.uk/amcharts/temperature10.html .... it makes excellent viewing and is better than a lot of stuff on Netflix.
    .... Could be something to do with the air filter we're using:
  • Phyto-active CO2 scrubbers installed
    Capt. Flatus O'Flaherty • 12/09/2022 at 13:22 • 0 comments
  • Website built for product sales
    Capt. Flatus O'Flaherty • 12/08/2022 at 11:07 • 0 comments
    https://themushroommafia.onlineweb.shop/
  • Online sensor displays
    Capt. Flatus O'Flaherty • 12/07/2022 at 19:18 • 0 comments
    The sensor results can also be seen live at these locations: http://www.goatindustries.co.uk/amcharts/temperature10.html ..... and the raw data here: http://www.goatindustries.co.uk/mushroom_mafia/showdata.php
  • Fruiting Shiitake Blocks Unwrapped
    Capt. Flatus O'Flaherty • 12/06/2022 at 18:44 • 0 comments
  • Grapical Results from Sensor Array
    Capt. Flatus O'Flaherty • 12/06/2022 at 18:42 • 0 comments
  • The 'Shrooms have arrived.
    Capt. Flatus O'Flaherty • 12/05/2022 at 16:46 • 0 comments
    Shiitake and King Oyster mushroom blocks now on the racks ready to start fruiting.
  • Sensor box is ready for action
    Capt. Flatus O'Flaherty • 12/04/2022 at 10:22 • 0 comments
    The sensors, fan, power supply and circuit board are bolted inside a water-proof polycarbonate enclosure with two sets of pipes attached.
    The left side is the air inlet and the right the outlet with air pulled slowly through with a 5V fan. It was much easier to mount the equipment on one of the shelving units than start drilling holes in the stainless steel paneling of the shipping container as it will inevitably need to be moved around a bit to find the optimum position. Just need to connect the external LoRa antenna and it's ready to go.
View all 9 project logs
Log In/Sign up to comment
Sign up with Github
OR
Roger S wrote 12/08/2022 at 17:39 • point
Curious: why particulates?  Seems like they could be any number of sources.  Spores?  Molds?  Air pollution?  Dust?
Capt. Flatus O'Flaherty wrote 12/08/2022 at 18:03 • point
Good question. The previous owner of our shipping container was getting some spoilt batches due to contamination from somewhere and was not sure where it was coming from He thought that it could be due to dust being blown into the box as it was sited on a dusty farm yard. Alternatively, it could have been from poorly sterilised blocks at the supplier's plant. We chose to measure the general contaminants, not being too concerned what they were as if the sensor picked up dust then there are probably plenty of foreign spores in that dust. We also wanted to see what effect walking into the container had and if we could keep particulates down by keeping the floor wet. There's also a fan for bringing in fresh air which blows through a filter. If the filter fails for some reason, we'll be able to detect that. There are probably some other reasons that I cant think of right now!
Johan wrote 12/08/2022 at 00:32 • point
This is very cool! I have started my own mushroom farm and am also doing a circuit design.
Capt. Flatus O'Flaherty wrote 12/08/2022 at 08:22 • point
Good stuff. If you need any help, give us a shout.
Dan Maloney wrote 11/29/2022 at 00:36 • point
Interesting -- I've actually been thinking about building a mushroom farm in the basement. I'll be watching this one closely.
Capt. Flatus O'Flaherty wrote 12/04/2022 at 11:20 • point
Just make sure the 'shrooms dont escape or they will eat your whole house!
The 2015 Hackaday Prize
Official Hackaday Prize Entry
An agricultural/horticultural automation and monitoring network for small to large scale production.
Project Owner Contributor
Growing of Things (GoT)
PeterPeter
A fully automated monitoring and self watering system for your backyard.
Automated urban garden system
Bruce MerloBruce Merlo
The cryogenic cooling system for the server cabinet
Phase-change cooling system for a rack servers
Andrew ShevchukAndrew Shevchuk
How can I spend >$100 and >100 hours to save $1 a year on air filters? They say to replace them every month, but is that really true?
When should I replace my A/C air filter?
Tim RightnourTim Rightnour
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "Mushroom Growing Control System", please tell us the reason.
Send message
Remove Member
