This is another case of making use of the 4 extra PCB’s that come with my order from China. The board is designed so that it can act as a diffuser over the blue LED matrix, which even at it’s lowest PWM is pretty bright. The circuit arranges component holes around the outside of the board, leaving a clear area in the middle for the digits to glow through.
The display is off in daylight and late at night/early in the morning.
In the past, when using an LDR to control brightness I keep a rolling average reading. This time I just treated the LDR value (in relation to a threshold) as a debounced “switch”.
Pins.h in the sketch has a schematic and parts details.
More photos:
Arduino board:
LED matrix:
Mark Wilson
