COMPONENT CHOICES
Servos I used to have metal gears and they are a little bit less crappy than plastic ones. Servos work on 5-6 volts and 18 of them draw around 4 amps constantly while the robot is working. that is why I went with 5A UBEC from hobby king. I tried some cheaper ones from eBay but they just didn't work. You can use any battery of similar size, it just needs to be 2S or more(7,4 volts or more) and can provide more than 5 amps. The servo controller is lynxmotion SSC32-U and you don't have a lot of picking here, almost all hexapods on the internet use this one or an older version. So Arduino. I had that small version of Arduino mega lying around and was not using it for anything special so I decided to use it. On top of that, I will try to make it autonomous in the future and add some more functions that will require more memory and IO. it should be possible to use Arduino pro mini or Arduino nano BUT you will need to use different code that uses software serial because mega has more than one serial port. The PS2 controller and receiver should work if you buy them from eBay or anywhere else because we will take apart the receiver and will not use those custom-made connectors that come with it if you order from lynxmotion or RobotShop.
3D Print Parts
You will need to print all parts in STL file. Support is needed for the 9V battery holder, coxas, and the battery lid. I printed with PLA and 0.2 layer height. ALL parts need to be printed once EXCEPT:
- 6xTibia
- 6xFemur
- 3xCoxa
- 3xCoxa mirror
- 2xFront holder
Petar Crnjak
Tom_Neverwinter
deʃhipu
cyplesma
Don Juan De Pyro
