Everything in this project can kill you.
I'm not an engineer, I'm not a programmer nor do I have any kind of useful expertise.
You shouldn't be doing this DIY project without professional help.
You can die. You've been warned.
Project summarization:
https://docs.google.com/document/d/1qyQYm0QjpYjyiu1zU5EMsVFoiNilVkun_hlkQe6SLAA/edit?usp=sharing
In summary:
- It is too complex for a single person to make it alone, I would need a degree on electrical engineering, mechanical engineering, electronic engineering and electrochemistry in order to design and build everything from scratch.
(to this day I still couldn't find exactly how much power each actuator would need to output, so if I'm having difficult with just that, imagine the rest) - For a mech that runs at the same speed as an human being (14 kilometers per hour), you would need so much power that the machine would consume dozens of kilograms of gasoline per hour while a conventional wheeled vehicle can go much faster at lower fuel usage.
- I'm super broke and I would need to try to build it multiple times using multiple tools which I can't afford.
I always thought it would be an actuator problem or the like, but I was wrong.
(I only talk about the essentials and more promising ideas of the project, however, none of them are proved to work, this project was researched knowingly it was doomed to never work, but it was done so for fun.)
Well, the thing is: I kinda wanted to make Project Log 90 the final project log...
However, I kept procrastinating, and procrastinating, and procrastinating, and procrastinating so much that I eventually reached 800 pages on google docs (link). And now I kinda gave up on the project...
... At least until I feel like trying to continue it again.
So, from Project Log 91 to Project Log 121, I'm just copy-pasting the Project Log 90 into the Hackaday blog because it is too long to fit in a single project log.
Confusing? Yeah, sometimes I feel like whatever the hell I write looks like the ramblings of a madman.
(I have ADHD, Depression and Anxiety [I am medicated {I've done this project just to keep me sane as a distraction to everything happening in the world and around me}])
Index:
- Project log 79: Testing things out.
- Project Log 80: Screw it, let's freaking do it.
- Project Log 81: Screw it, let's freaking do it.²
- Project Log 82: Types of mechs that may be viable/practical.
- Project Log 83: Screw it, let's freaking do it.³
- Project Log 84: Screw it, let's freaking do it.⁴
- Project Log 85: Screw it, let's freaking do it.⁵
- Project Log 86: Screw it, let's freaking do it.⁶
- Project Log 87: Screw it, let's freaking do it.⁷
- Project Log 88: Screw it, let's freaking do it.⁸
- Project Log 89: Screw it, let's freaking do it.⁹
- Project Log 90: "Final" Project Log.
- Project Log 91: "Final" Project Log.1
- Project Log 92: "Final" Project Log.2
- Project Log 93: "Final" Project Log.3
- Project Log 94: "Final" Project Log.4
- Project Log 95: "Final" Project Log.5
- Project Log 96: "Final" Project Log.6
- Project Log 97: "Final" Project Log.7
- Project Log 98: "Final" Project Log.8
- Project Log 99: "Final" Project Log.9
- Project Log 100: "Final" Project Log.10
- Project Log 101: "Final" Project Log.11
- Project Log 102: "Final" Project Log.12
- Project Log 103: "Final" Project Log.13
- Project Log 104: "Final" Project Log.14
- Project Log 105: "Final" Project Log.15
- Project Log 106: "Final" Project Log.16
- Project Log 107: "Final" Project Log.17
- Project Log 108: "Final" Project Log.18
- Project Log 109: "Final" Project Log.19
- Project Log 110: "Final" Project Log.20
- Project Log 111: "Final" Project Log.21
- Project Log 112: "Final" Project Log.22
- Project Log 113: "Final" Project Log.23
- Project Log 114: "Final" Project Log.24
- Project Log 115: "Final" Project Log.25
- Project Log 116: "Final" Project Log.26
- Project Log 117: "Final" Project Log.27
- Project Log 118: "Final" Project Log.28
- Project Log 119: "Final" Project Log.29
- Project Log 120: "Final" Project Log.30
- Project Log 121: "Final" Project Log.31
Damn, now that I finished post this project log, I feel like a weight was lifted from my shoulders...
