Well, this project is pretty much dead.
I'm talking this "in the moment" so to speak, and I may or may not change my mind later.
But in summary: I'm broke.
It is unrealistic to simply think "I will be doing little by little" when I don't even have the money to buy the cheapest hydraulic gear pump.
It is not possible for me to simply make 3D models for physical objects that I don't even have the condition to buy and assemble, after all, even the screws are expensive (to me).
Yeah, I said in the project description that mechs are expensive, and I'm giving up on the project because I don't have the money for the cheapest mech/exosuit that I could think of.
There is probably someone out there with enough spare time, focus and money that could make this project a reality, but right now I feel that this person is not me.
This is a guide, not a instruction's book.
Well, the idea of this project is to be more of a guide-book rather than a rule-book, I will make my own stuff, but it doesn't mean you can't learn other things that could be useful for your specific needs.
Plus, I'm not even an engineer, a professional would have finished this project a long time ago.
The project logs are long and counting up, my apologies for that, but if you want to really just start where the project truly starts, go to Project Log 54 forward.
Previous project logs are more or less about exploring every option that I could find and learning all the necessary stuff for the project rather than an actual manual.
That's why I think it could be relevant for you to read everything first if you aren't familiar with engineering in general, or if you just want to understand why I abandoned certain ideas and kept working with other.
During the project, I changed my mind a myriad of different times about how to build this thing, and in hindsight, I think it was for the best.
So I think it is worth making the choice of studying every option before actually committing to build it. I saved so much money that I would otherwise have expended for dead ends that I didn't knew it were dead ends.
Right now I'm writing Project Log 68, so I'm more or less on the "final steps" before actually building the thing itself.
Again, this is not a "connect part 2B with part 3A in this way", this is more of a "I connected part 1, 2 and 3 this way because I think it would be stronger and easier to build, if there is a better way, I don't know, but I heard that you could connect these parts in a X configuration, which I never tested before" kind of DIY guide.
