Shrink this stuff down!
01/05/2017 at 02:49 • 0 comments(Forgive the Walking Dead homage)
I applied some supernatural ways to shrink the final size of our binary down, plan to add a separate section on the hackaday page describing some of the techniques.
Thermistors soldered up
01/05/2017 at 02:46 • 0 commentsWe repurposed some old phone cable and soldered up six 10K thermocouples to the LED board. We drilled through the back of the board so the thermistors could sense heat from the front, either from a heat gun or even just touching it with your finger.
A little too late too get much further tonight, but hopefully our board will be glowing soon
Battle of the LED Painting Algorithms
01/05/2017 at 02:43 • 0 commentsThe LED matrix is actually made up of 12 smaller (8x8) boards that are connected together. This requires an interesting (painful) algorithm for getting our color map to display correctly.
As Adam stated in 242560:
Because Jordan soldered the LED matrix without care and respect for the
rest of us, a significant amount of mapping has to be done from the
temperature array to the LED layout.Adam made a decent attempt, but didn't quite get it right. It also took him a fair amount of convincing that his algorithm was junk, but a few tests and a final working solution put us all back on track.
Uh-oh 32x24x2 too big!
01/05/2017 at 02:27 • 0 commentsOur J-Goulder manufactured LED board has 32x24 LEDs and we definitely want to light the whole thing up with just our spare Arduino Uno. This would normally be no problem, but our transient conduction algorithm requires two arrays at a time (one for the current time step, one for the previous). This kind of pushes our RAM requirements too the limit.
brewlius-cesar thought of a quick way to trim down the fat of our algorithm by keeping only a single row of "previous" values and swapping out the values as we do our radial sweeps for each time step.
Created a Github Repositiory
01/05/2017 at 02:19 • 0 commentsWe have a repository:
Initial Idea
01/05/2017 at 02:16 • 0 commentsAdam has an idea:
We add a few temperature sensors to each edge of Jordan's led screen. You hold it, and the led colors reflect the temperature around the edge, which is the initial condition. You hit a button, and it acts like a box full of water, showing natural convection driven by the initial edge temperature that you gave it
Adam Spontarelli
