Ravinder London-based embedded engineer launched an amazing LTE HAT on Kickstarter, Ravinder has already created and delivered two successful campaigns USB to TTL & Sense HAT for Pico. Now he has come up with PiTalk 4G IoT HAT which is compatible with all Raspberry Pi Models having 40 Pins GPIO on it and also he has taken care of non-Raspberry Pi users by introducing 4G USB Dongle which supports all platforms that just need a USB port to get started with it.
PiTalk IoT HAT can be used as a smartphone as it supports SMS, Calling features, Video calling, and many other smartphone features can be used with PiTalk. PiTalk uses the Quectel EG25-G Cat 4 module With maximum downlink and uplink speeds of 150 Mbps and 50 Mbps under LTE, respectively, and backward compatibility with existing 2G networks, the Quectel EG25-G Cat 4 module offers connectivity even in distant locations lacking 3G or 4G coverage. Additionally, MIMO technology satisfies the requirements for data throughput and link dependability.
Features & Specifications :
- Quectel EG25-G Cat 4 module
- Worldwide LTE, UMTS/HSPA+, and GSM/GPRS/EDGE coverage
- Supports MIMO
- Supports DFOTA and DTMF
- Multi-constellation GNSS receiver available
- Max. 150Mbps DL/ 50Mbps UL
- USSD Support
- Voice Calls & SMS
- SIM Holder
- Bluetooth
- 3.5mm Audio Jack
- Support Windows/Linux
- Multihost Support
- LED Indicators
- Jumper Selection
The optional multi-constellation GNSS receiver substantially simplifies product design and offers faster, more accurate, and more reliable positioning. PiTalksupports Qualcomm IZat location technology Gen8C Lite (GPS, GLONASS, BeiDou/Compass, Galileo, and QZSS).
PiTalk has an onboard nano-SIM card and It has USB type C to Power up the board it could be the independent solution to access the internet and it has the ability to control smart appliances or develop your own applications, Utilize them to create hotspots using WAP technology and gain access to the internet wherever you are.
PiTalk is currently available on Kickstarter in two form factor USB Dongle & Raspberry Pi HAT with capabilities of 2G & 4G technologies, Ravinder also offers Raspberry Pi Boards as his reward, PiTalk prices is starting from £20 and He'll deliver PiTalk by February 2023.
